Sub JoinC()
Dim rSelected As Range
Dim c As Range
Dim sArgs As String
Dim bConcat As Boolean
Dim bOptions As Boolean
Dim sArgSep As String
Dim sSeparator As String
Dim rOutput As Range
Dim lTrim As Long
Dim sTitle As String
'Set variables
Set rOutput = ActiveCell
bConcat = False
bOptions = False
sSeparator = ", "
sTitle = "Join"
'Prompt user to select cells for formula
Set rSelected = Application.InputBox(Prompt:= _
"Select cells to create formula", _
Title:=sTitle & " Creator", Type:=8)
On Error GoTo 0
'Only run if cells were selected and cancel button was not pressed
If Not rSelected Is Nothing Then
'Set argument separator for join formula
sArgSep = "&"
'Create string of cell references
For Each c In rSelected.Cells
sArgs = sArgs & c.Address & sArgSep
'& ActiveSheet.Name
If sSeparator <> "" Then
sArgs = sArgs & Chr(34) & sSeparator & Chr(34) & sArgSep
'Trim extra argument separator and separator characters
lTrim = 4 + Len(sSeparator) ' IIf(sSeparator <> "", 4 + Len(sSeparator), 1)
sArgs = Left(sArgs, Len(sArgs) - lTrim)
'Create formula
rOutput.Formula = "=" & sArgs
