If Not Intersect(Target, Range("BB10:BB5000")) Is Nothing Then
ActiveCell(1, -24).Select
ActiveCell.ClearComments
If Target <> "" Then
ActiveCell.Select
With ActiveCell.AddComment
.Text Text:=" << Controlla >> " & Chr(10) & "le annotazioni presenti" & Chr(10) & " con un doppio click"
.Shape.ScaleWidth 0.95, msoFalse, msoScaleFromTopLeft
.Shape.ScaleHeight 0.75, msoFalse, msoScaleFromTopLeft
ElseIf Target = "" Then
ActiveCell(1, -24).ClearComments
End If |
Sub test()
Dim r As Integer
Dim xRange As Range
'* Add Comment:
For Each xRange In Selection
With xRange
.ClearComments
.AddComment "Test" & Chr(10) & "Valore cella= " & xRange.Value
.Comment.Visible = True
.Comment.Shape.AutoShapeType = msoShapeRoundedRectangle
.Comment.Shape.TextFrame.Characters.Font.Name = "Tahoma"
.Comment.Shape.TextFrame.Characters.Font.Size = 8
.Comment.Shape.TextFrame.Characters.Font.ColorIndex = 2
.Comment.Shape.Line.ForeColor.RGB = RGB(0, 0, 0)
.Comment.Shape.Line.BackColor.RGB = RGB(255, 255, 255)
.Comment.Shape.Fill.Visible = msoTrue
.Comment.Shape.Fill.ForeColor.RGB = RGB(58, 82, 184)
.Comment.Shape.Fill.OneColorGradient msoGradientDiagonalUp, 1, 0.23
'font size Attribute
.Comment.Shape.TextFrame.Characters(1, 1).Font.Color = vbRed
.Comment.Shape.TextFrame.Characters(6, 6).Font.Color = vbYellow
.Comment.Shape.TextFrame.Characters(1, 1).Font.Size = 24
.Comment.Shape.TextFrame.Characters(6, 6).Font.Size = 12
Next xRange
Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, Cancel As Boolean)
If Not Intersect(Target, Range("AX10:AX5000")) Is Nothing Then
If Target = "SI" Then
Target = "NO"
ElseIf Target = "NO" Then
Target = "SI"
ActiveCell(1, -2).Select
Selection.Copy
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, _
SkipBlanks:=False, Transpose:=False
ActiveCell(1, -5).Select
Selection.ClearContents
If Not Intersect(Target, Range("AC10:AC5000")) Is Nothing Then
ActiveCell(1, 26).Select
ActiveCell.Select
.Visible = False
.Shape.ScaleWidth 0.72, msoFalse, msoScaleFromTopLeft
.Shape.ScaleHeight 0.47, msoFalse, msoScaleFromTopLeft
With ActiveCell.Comment.Shape.TextFrame.Characters.Font
.Name = "Tahoma"
.Size = 7
.Bold = False
.Italic = False
'.Color = RGB(0, 0, 255)'<< Blu or (255,0,0)<< Rosso (0,153,76) << Verde scuro (128,0,0) << Marrone
.Color = vbBlue
If Not Intersect(Target, Cells) Is Nothing Then
Range("D1").Value = Target.Row
Sub ImpostaCommento()
Dim r As Integer
Dim xRange As Range
r = Cells(1, 4).Value
'* Add Comment:
With xRange
.ClearComments
.AddComment "Annotazioni presenti:" & Chr(10) & Cells(r, 54).Value
.Comment.Visible = False
.Comment.Shape.TextFrame.Characters.Font.Size = 6
.Comment.Shape.TextFrame.Characters(2, 20).Font.Color = vbYellow
.Comment.Shape.TextFrame.Characters(1, 1).Font.Size = 9
.Comment.Shape.TextFrame.Characters(2, 20).Font.Size = 8
.Comment.Shape.ScaleWidth 0.95, msoFalse, msoScaleFromTopLeft
.Comment.Shape.ScaleHeight 0.95, msoFalse, msoScaleFromTopLeft
Next xRange
Application.Calculation = xlCalculationManual
Application.DisplayStatusBar = False
ActiveSheet.DisplayPageBreaks = False
Dim xRange As Range
'* Add Comment:
With xRange
.ClearComments
.AddComment "Annotazioni presenti:" & Chr(10) & Cells(Target.Row, 54).Value
.Comment.Shape.TextFrame.AutoSize = True
Next xRange
Application.Calculation = xlCalculationAutomatic
Application.DisplayStatusBar = True
Cancel = True
ActiveCell.Select
'con doppio click su una cella della colonna scelta modifica il valore contenuto
'se "Si" in "No" altrimenti se "No" in "Si" fissando con la conferma
'il valore unitario nella cella del prezzo a mano.
Target = "NO"
Target = "SI"
Selection.Copy
ActiveCell.Select
Call ImpostaCommento
'Application.EnableEvents = False
'Application.Calculation = xlCalculationManual
'Application.ScreenUpdating = False
'Application.DisplayAlerts = False
'Application.DisplayStatusBar = False
'ActiveSheet.DisplayPageBreaks = False
Dim r As Integer
Dim xRange As Range
'* Add Comment:
With xRange
.ClearComments
.AddComment " Annotazioni presenti: " & Chr(10) & Cells(r, 54).Value
.Comment.Shape.Line.ForeColor.RGB = RGB(255, 135, 0)
'Font size Attribute:
.Comment.Shape.TextFrame.Characters(1, 2).Font.Color = RGB(255, 0, 25) 'RGB(255, 175, 0) 'Arancione
.Comment.Shape.TextFrame.Characters(3, 21).Font.Color = RGB(255, 255, 0) 'or vbYellow
.Comment.Shape.TextFrame.Characters(1, 2).Font.Size = 9
.Comment.Shape.TextFrame.Characters(3, 21).Font.Size = 8
Next xRange
'Application.Calculation = xlCalculationAutomatic
'Application.DisplayStatusBar = True
'Application.ScreenUpdating = True
'Application.EnableEvents = True
