Sub ImportPDFFileData() 'Author: Steve Lipsman 'Purpose: Import PDF File Data Into Excel Worksheet 'Other Requirement(s): 'Acrobat' Checked in VBA Tools-References 'Reference Renames Itself 'Adobe Acrobat 9.0 Object Library' After Reference Is Saved 'Declare Variable(s) Dim appAA As Acrobat.CAcroApp, docPDF As Acrobat.CAcroPDDoc Dim strFileName As String, intNOP As Integer, arrI As Variant Dim intC As Integer, intR As Integer, intBeg As Integer, intEnd As Integer 'Initialize Variables Set appAA = CreateObject("AcroExch.App"): Set docPDF = CreateObject("AcroExch.PDDoc") 'Set PDF FileName strFileName = "Your Full PDF File Pathname Here.pdf" 'Read PDF File docPDF.Open (strFileName) 'Extract Number of Pages From PDF File intNOP = docPDF.GetNumPages 'Select First Data Cell Range("A1").Select 'Open PDF File ActiveWorkbook.FollowHyperlink strFileName, , True 'Loop Through All PDF File Pages For intC = 1 To intNOP 'Go To Page Number SendKeys ("+^n" & intC & "{ENTER}") 'Select All Data In The PDF File's Active Page SendKeys ("^a"), True 'Right-Click Mouse SendKeys ("+{F10}"), True 'Copy Data As Table SendKeys ("c"), True 'Minimize Adobe Window SendKeys ("%n"), True 'Paste Data In This Workbook's Worksheet ActiveSheet.Paste 'Select Next Paste Cell Range("A" & Range("A1").SpecialCells(xlLastCell).Row + 2).Select 'Maximize Adobe Window SendKeys ("%x") Next intC 'Close Adobe File and Window SendKeys ("^w"), True 'Empty Object Variables Set appAA = Nothing: Set docPDF = Nothing 'Select First Cell Range("A1").Select End Sub |
