Sub SelectSheets()
Dim PrintDlg As DialogSheet
Dim cb As CheckBox, Wbname As String, DTAddress As String
DTAddress = CreateObject("WScript.Shell").SpecialFolders("Desktop") & Application.PathSeparator
Set PrintDlg = ActiveWorkbook.DialogSheets.Add
SheetCount = 0
' Add the checkboxes
TopPos = 40
For i = 1 To ActiveWorkbook.Worksheets.Count
Set CurrentSheet = ActiveWorkbook.Worksheets(i)
' Skip empty sheets and hidden sheets
If Application.CountA(CurrentSheet.Cells) <> 0 And _
CurrentSheet.Visible Then
SheetCount = SheetCount + 1
PrintDlg.CheckBoxes.Add 78, TopPos, 150, 16.5
PrintDlg.CheckBoxes(SheetCount).Text = _
CurrentSheet.Name
TopPos = TopPos + 13
' Move the OK and Cancel buttons
PrintDlg.Buttons.Left = 240
' Set dialog height, width, and caption
With PrintDlg.DialogFrame
.Height = Application.Max _
(68, PrintDlg.DialogFrame.Top + TopPos - 34)
.Width = 230
.Caption = "Select sheets to print"
' Change tab order of OK and Cancel buttons
' so the 1st option button will have the focus
PrintDlg.Buttons("Button 2").BringToFront
PrintDlg.Buttons("Button 3").BringToFront
' Display the dialog box
CurrentSheet.Activate
If SheetCount <> 0 Then
If PrintDlg.Show Then
For Each cb In PrintDlg.CheckBoxes
If cb.Value = xlOn Then
Sheets(cb.Caption).Select
pdfname = Sheets(cb.Caption).Name
ActiveSheet.ExportAsFixedFormat Type:=xlTypePDF, Filename:= _
DTAddress & pdfname & ".pdf", Quality:= _
xlQualityStandard, IncludeDocProperties:=True, IgnorePrintAreas:=False, _
OpenAfterPublish:=True
' ActiveSheet.PrintPreview 'for debugging
Next cb
MsgBox "All worksheets are empty."
' Delete temporary dialog sheet (without a warning)
' Application.DisplayAlerts = False
PrintDlg.Delete
