Private Sub Creabudgetcdc_Click()
Dim Question As Integer
Dim mypath As String
Dim nFile As String
Question = MsgBox("Vuoi salvare il file?", vbYesNo + vbCritical, "Attenzione")
Select Case Question
Case vbNo
Case vbYes
mypath = "M:Ufficio Finanza e Controllo 1 - BudgetBdg 2017\_Modello "
nFile = [B1] & "-" & [C1]
ActiveWorkbook.SaveAs Filename:=mypath & nFile & ".xlsm", FileFormat:= _
xlOpenXMLWorkbookMacroEnabled, CreateBackup:=False
' Crea una copia del foglio master e lo rinomina con il nome del cdc
Sheets("Master").Select
Sheets("Master").Copy After:=Sheets(23)
ActiveSheet.Name = ActiveSheet.Range("B1")
' Trova e cancella la parola "Totale complessivo"
With ActiveSheet.Cells
.Replace What:="Totale complessivo", Replacement:=""
' Copia a valore il conto economico 2016
Range("E5:E13").Select
Selection.Copy
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
Range("C1").Select
Selection.Copy
' Copia a valore l'area con i dettagli del Budget e chiude le colonne
Columns("EL:IC").Select
Selection.Copy
Columns("BX:IC").Select
Selection.Columns.Group
ActiveSheet.Outline.ShowLevels RowLevels:=0, ColumnLevels:=1
' Protegge il foglio
ActiveSheet.Protect DrawingObjects:=True, Contents:=True, Scenarios:=True
MsgBox ("File salvato")
End Select
