Sub duplica()
Dim fso As Object, fo As String, i As Integer, j As Integer
Dim excelfile As Object, wb As Object
Set fso = CreateObject("scripting.filesystemobject")
With Application.FileDialog(msoFileDialogFolderPicker)
.Title = "Seleziona la cartella con i file Excel"
If .Show = 0 Then Exit Sub
fo = .SelectedItems(1)
j = fso.getfolder(fo).Files.Count
For Each excelfile In fso.getfolder(fo).Files
Application.StatusBar = "Restano " & j & " files da esaminare..."
i = InStrRev(excelfile, ".")
If Mid(excelfile, i + 1) Like "xls*" Then
Set wb = Workbooks.Open(excelfile)
With wb
.Sheets("Foglio2").Copy After:=.Sheets(.Sheets.Count)
.Sheets(.Sheets.Count).Name = "Foglio" & .Sheets.Count
wb.Close True
j = j - 1
Application.StatusBar = ""
Set excelfile = Nothing
Set fso = Nothing
MsgBox "Tutto fatto."
