Dim RetVal
RetVal = Shell("C:WINDOWS
otepad.exe C:miofilechehoappenacreato.txt", 1) |
Sheets("miofoglio").SaveAs Filename:="D:Reportsmiotesto.txt", FileFormat:=xlTextMSDO |
Dim MyDir As String, NomeFile As String
MyDir = ThisWorkbook.Path
With Application.GetSaveAsFilename(InitialFileName:=NomeFile, fileFilter:="File txt, *.txt,Testo Unicode, *.txt")
ActiveSheet.Copy
With ActiveWorkbook
.SaveAs Filename:=NomeFile, FileFormat:="File txt, *.txt,Testo Unicode, *.txt"
'.SaveAs Filename:=NomeFile, FileFormat:=xlUnicodeText
.Close savechanges:=False
Sub saveAsDialogText() ChDrive "F" ChDir "F:Download" fileSaveName = Application.GetSaveAsFilename(fileFilter:="txt Files (*.txt), *.txt") If fileSaveName <> False Then ActiveSheet.Copy ActiveWorkbook.saveas filename:=fileSaveName, FileFormat:=xlUnicodeText ActiveWorkbook.Close False End If End Sub |
Private Sub CommandButton1_Click() MyDir = ThisWorkbook.Path fileSaveName = Application.GetSaveAsFilename(fileFilter:="txt Files (*.txt), *.txt") If fileSaveName <> False Then ActiveSheet.Copy ActiveWorkbook.SaveAs Filename:=fileSaveName, FileFormat:=xlUnicodeText ActiveWorkbook.Close False End If End Sub |
