AddComment..Text Foglio2.Cells(1, 1) |
If Not Intersect(Target, Range("A1:A10")) Is Nothing Then
opt = Target.Value: If opt = "" Then Exit Sub
cmm = Application.WorksheetFunction.VLookup(ActiveCell.Text, Sheets(2).Range("tabella"), 2, False)
Cells(Target.Row, Target.Column).ClearComments
Cells(Target.Row, Target.Column).AddComment
Cells(Target.Row, Target.Column).Comment.Visible = False
Cells(Target.Row, Target.Column).Comment.Text Text:=cmm
Set myrange = Worksheets("foglio2").Range("tabella")
cmm = Application.WorksheetFunction.VLookup(target.Value, myrange, 2, False)
If Not Intersect(Target, Range("L2:L10000")) Is Nothing Then
Set myrange = Worksheets("routine").Range("tabella")
cmm = Application.WorksheetFunction.VLookup(Target.Value, myrange, 2, False)
