Sub aggiornaMastro()
Dim fgDa As Worksheet, fgA As Worksheet
Dim Ur As Integer, Ctg As Integer, deb As Double, cre As Double
Set fgDa = Worksheets("Libro giornale")
Set fgA = Worksheets("Libro mastro")
Ur = fgDa.Cells(65536, 2).End(xlUp).Row
For r = 7 To Ur
'MsgBox ("Riga " & r)
If Cells(r, 2).Value = 9 Then
deb = Cells(r, 5).Value
cre = Cells(r, 6).Value
Call MandaInNove(fgA, deb, cre)
Sub MandaInNove(fgA As Worksheet, deb As Double, cre As Double)
MsgBox ("MANDO IN NOVE : " & " " & deb & " " & cre)
'fgA.Range("nove").Select 'NON FUNZIONA !
Sheets(fgA).Select
Range("nove").Select 'NON FUNZIONA NEMMENO QUESTO !
MsgBox ("controllo cella destinazione")
For r = 7 To Ur
' (non serve più) MsgBox ("MANDO IN NOVE : " & " " & deb & " " & cre)
fgA.Select
fgA.Range("nove").End(xlDown).Offset(1, 0).Select
' (non serve più) MsgBox ("controllo cella destinazione")
ActiveCell.Value = deb
ActiveCell.Offset(0, 1).Value = cre
Dim Ur As Integer, Ctg As Integer, cap As Integer
Dim deb As Double, cre As Double
Dim capitoli As Variant, capito As String
capitoli = Array("uno", "due", "tre", "quattro", "cinque")
For r = 7 To Ur
For c = 0 To 4
cap = fgA.Range(capitoli(c)).Value 'perché dentro alla cella che si chiama "uno" c'è scritto "1"
capito = capitoli(c)
If fgDa.Cells(r, 2).Value = cap Then
deb = fgDa.Cells(r, 5).Value
cre = fgDa.Cells(r, 6).Value
Call MandaInMastro(fgA, capito, deb, cre)
fgDa.Cells(r, 2).Value = "-" & cap
Next c
Next r
Sub MandaInMastro(fgA As Worksheet, capito As String, deb As Double, cre As Double)
fgA.Select
fgA.Range(capito).End(xlDown).Offset(1, 0).Select
