Dim c As Range, s As String
Dim sh As Variant
If Intersect(Target, Range("A:A")) Is Nothing Then Exit Sub
If Target.Cells.Count > 1 Then Set Target = Target.Resize(1, 1)
If Trim(Target) = "" Then Exit Sub
s = ""
'cerca nel foglio 1 e nel foglio 3 il dato digitato in A
For Each sh In Array(Sheets("1"), Sheets("3"))
Set c = sh.Range("A:A").Find(Target, LookAt:=xlWhole)
If Not (c Is Nothing) Then
If s = "" Then
s = "Articolo usato nel foglio " & sh.Name
Target.Offset(, 1) = s
Target.Offset(, 2) = c.Offset(, 2)
s = s & "-" & sh.Name
Sub Worksheet_Change(ByVal Target As Excel.Range)
Dim strCellaModificata As String
Dim strColonna As String
Dim strRiga As String
Dim intrisposta As Integer
Dim y As Long, Rng As Range, firstAddress As String
Dim blnTrovato As Boolean
Dim strWorkbook As String
Dim Riga As Long, LastRow As Long, Col As Long, ColS As String
Dim ID As String, Sh1 As Worksheet, RangeMaster As Range, RangeSingolo As Range
Set RangeMaster = Range("C9:C" & Cells(Rows.Count, "C").End(xlUp).Row)
Set RangeSingolo = Range("D9:D" & Cells(Rows.Count, "D").End(xlUp).Row)
If Target.Count > 1 Then Exit Sub
If Not Intersect(Target, RangeMaster) Is Nothing Or Not Intersect(Target, RangeSingolo) Is Nothing Then
Col = Target.Column
If Col = 3 Then ColS = "B": If Col = 4 Then ColS = "A"
Const conPercorso = "\CLUSTERFSSharePiano MarketingDb_MasterDb_Generale_db_new" 'new
strWorkbook = ActiveWorkbook.Name
Workbooks.Open Filename:=conPercorso & "dbnew.xlsm", ReadOnly:=True
LastRow = Workbooks("dbnew.xlsm").Worksheets("db").Cells(Rows.Count, Col).End(xlUp).Row
Riga = Cells(Rows.Count, "D").End(xlUp).Row + 1
If Riga < 9 Then Riga = 9
Workbooks(strWorkbook).Activate
Set Sh1 = Workbooks(strWorkbook).ActiveSheet
ID = Target.Value
With Workbooks("dbnew.xlsm").Worksheets("db").Range(ColS & "2:" & ColS & LastRow)
Set Rng = .Find(What:=ID, LookAt:=xlWhole, LookIn:=xlValues)
If Not Rng Is Nothing Then
blnTrovato = True
If ColS = "B" Then
firstAddress = Rng.Address
Do
Sh1.Range("D" & Riga).Value = Rng.Offset(0, -1)
Sh1.Range("E" & Riga).Value = Rng.Offset(0, 0)
Sh1.Range("J" & Riga).Value = Rng.Offset(0, 1)
Sh1.Range("H" & Riga).Value = Rng.Offset(0, 4)
Sh1.Range("I" & Riga).Value = Rng.Offset(0, 5)
Sh1.Range("G" & Riga).Value = Rng.Offset(0, 3)
Sh1.Range("K" & Riga).Value = Rng.Offset(0, 6)
Sh1.Range("P" & Riga).Value = Rng.Offset(0, 8)
Sh1.Range("V" & Riga).Value = Rng.Offset(0, 7)
Sh1.Range("Y" & Riga).Value = Rng.Offset(0, 13)
Sh1.Range("AA" & Riga).Value = Rng.Offset(0, 14)
Sh1.Range("AB" & Riga).Value = Rng.Offset(0, 19)
Sh1.Range("AC" & Riga).Value = Rng.Offset(0, 20)
Sh1.Range("A" & Riga).Value = Rng.Offset(0, 18)
Sh1.Range("B" & Riga).Value = Rng.Offset(0, 16)
Sh1.Range("AE" & Riga).Value = Rng.Offset(0, 23)
Sh1.Range("AI" & Riga).Value = Rng.Offset(0, 25)
Sh1.Range("AJ" & Riga).FormulaR1C1 = "=IF(ISERROR(RC[-7]*RC[-24]),0,(RC[-7]*RC[-24]))"
Sh1.Range("AK" & Riga).FormulaR1C1 = "=IF(ISERROR(RC[-8]*RC[-20]/1.22),0,(RC[-8]*RC[-20]/1.22))"
Riga = Riga + 1
Set Rng = .FindNext(Rng)
Loop While Not Rng Is Nothing And Rng.Address <> firstAddress
Sh1.Range("E" & Riga - 1).Value = Rng.Offset(0, 0)
Sh1.Range("J" & Riga - 1).Value = Rng.Offset(0, 2)
Sh1.Range("H" & Riga - 1).Value = Rng.Offset(0, 5)
Sh1.Range("I" & Riga - 1).Value = Rng.Offset(0, 6)
Sh1.Range("G" & Riga - 1).Value = Rng.Offset(0, 4)
Sh1.Range("K" & Riga - 1).Value = Rng.Offset(0, 7)
Sh1.Range("P" & Riga - 1).Value = Rng.Offset(0, 9)
Sh1.Range("V" & Riga - 1).Value = Rng.Offset(0, 8)
Sh1.Range("Y" & Riga - 1).Value = Rng.Offset(0, 14)
Sh1.Range("AA" & Riga - 1).Value = Rng.Offset(0, 15)
Sh1.Range("AB" & Riga - 1).Value = Rng.Offset(0, 20)
Sh1.Range("AC" & Riga - 1).Value = Rng.Offset(0, 21)
Sh1.Range("A" & Riga - 1).Value = Rng.Offset(0, 19)
Sh1.Range("B" & Riga - 1).Value = Rng.Offset(0, 17)
Sh1.Range("AE" & Riga - 1).Value = Rng.Offset(0, 24)
Sh1.Range("AI" & Riga - 1).Value = Rng.Offset(0, 26)
Sh1.Range("AJ" & Riga - 1).FormulaR1C1 = "=IF(ISERROR(RC[-7]*RC[-24]),0,(RC[-7]*RC[-24]))"
Sh1.Range("AK" & Riga - 1).FormulaR1C1 = "=IF(ISERROR(RC[-8]*RC[-20]/1.22),0,(RC[-8]*RC[-20]/1.22))"
Workbooks("dbnew.xlsm").Close
If blnTrovato = False Then
intrisposta = MsgBox("Il prodotto inserito non è presente nell'archivio, " _
& "vuoi aprire il file dbnew per aggiungerlo?", vbYesNo)
If intrisposta = vbYes Then
frmPassword.Show
Set Sh1 = Nothing
Set Rng = Nothing
Set RangeMaster = Nothing
Set RangeSingolo = Nothing
End sub |
sh1 = ActiveSheet.Name -1: sh2 = ActiveSheet.Name + 1prestando naturalmente molta attenzione a gestire bene i due casi estremi in cui sia selezionato il foglio 1 (prima di questo non ci sono fogli) o l'ultimo (dopo il quale parimenti non ci sono fogli).
For Each sh In Array(Sheets(ActiveSheet.Name - 1), Sheets(ActiveSheet.Name + 1))
For Each sh In Array(ActiveSheet.Previous, ActiveSheet.Next)).
Private Sub Workbook_SheetChange(ByVal Sh As Object, ByVal Source As Range)cioè alla routine viene passato in argomento un oggetto "Sh" e un oggetto "Source", dove Sh è il foglio modificato, il Source è la cella (o un range di celle) che hanno subito la modifica.
Dim c As Range, s As String, ws As Variant
Dim wsheets As Variant
If Intersect(Source, Sh.Range("A:A")) Is Nothing Then Exit Sub
If Source.Cells.Count > 1 Then Set Source = Source.Resize(1, 1)
If Trim(Source) = "" Then Exit Sub
s = ""
'cerca nel foglio precedente e nel foglio successivo il dato digitato in A
If Sh.Index = 1 Then
wsheets = Array(Sh.Next)
ElseIf Sh.Index = ThisWorkbook.Sheets.Count Then
wsheets = Array(Sh.Previous)
wsheets = Array(Sh.Previous, Sh.Next)
For Each ws In wsheets
Set c = ws.Range("A:A").Find(Source, LookAt:=xlWhole)
If s = "" Then
s = "Articolo usato nei fogli: " & ws.Name
Source.Offset(, 1) = s
Source.Offset(, 2) = c.Offset(, 2)
s = s & "-" & ws.Name
If Intersect(Source, Sh.Range("A:B")) Is Nothing Then Exit Sub
s = ""
Set c = ws.Range("A:B").Find(Source, LookAt:=xlWhole)
If s = "" Then
Source.Offset(, 2) = s
Col = Target.Column
ID = Target.Value
blnTrovato = True
If ColS = "B" Then
Do
Riga = Riga + 1
frmPassword.Show
Set Sh1 = Nothing
Set Rng = Nothing
End sub |
' digito un codice in colonna A o B di qualunque foglio
' l'evento viene intercettato e se il codice digitato viene
' rinvenuto nel foglio precedente o in quello successivo
' allora vengono riportati i dati del codice trovato
' (compreso il nome del foglio in cui si trovano)
' dichiaro le variabili necessarie
' l'evento fornisce già un riferimento al foglio e al range modificato
Dim wsheets As Variant 'array che contiene il foglio prima e quello dopo
'alcuni controlli per evitare errori di compilazione.
'posso digitare solo in colonna A e in colonna B:
'viene ignorata la modifica delle prime due righe di ogni foglio:
If Source.Row <= 2 Then Exit Sub
'un range multicelle viene ridotto a una cella sola:
'se premo Canc elimina i dati della riga (celle A:D), ma chiede conferma:
If MsgBox("Eliminare?", vbYesNo + vbQuestion) = vbNo Then Application.Undo: Exit Sub
Application.EnableEvents = False 'importante per evitare ricorsione
Range(Sh.Cells(Source.Row, "A"), Sh.Cells(Source.Row, "D")).ClearContents
'disabilita gli eventi. E' importante disabilitare gli eventi
'in routine che intercettano gli eventi altrimenti si genera ricorsione
'gli eventi vengono riabilitati prima di uscire dalla routine
s = ""
'adesso si occupa di cercare il codice digitato bel foglio precedente e
'in quello successivo a quello che si sta modificando
'se il foglio modificato è il primo devi cercare solo nel successivo...
'altrimenti se il foglio è l'ultimo devi cecare solo nel precedente...
'altrimenti devi cercare sia nel precedente che nel successivo
'esamina ogni foglio nell'array di fogli da considerare
'imposta un riferimento alle colonne A e B del foglio in scansione
'e cerca in esse il valore digitato (Source)
'se non lo trova prosegue senza fare niente
'trovato! predispone la scritta per la colonna "Locazione"
'in cui inserisce il nome dei(l) fogli(o) in cui si trova il dato cercato
If s = "" Then
'completa l'inserimento dei dati
'se avevo digitato il codice in colonna A recupera il dato in colonna B
'e viceversa
If c.Column = 1 Then
Sh.Cells(Source.Row, "B") = ws.Cells(c.Row, "B")
Sh.Cells(Source.Row, "A") = ws.Cells(c.Row, "A")
'inserisce in colonna C ("Locazione") i dati recuperati dal foglio sorgente
Sh.Cells(Source.Row, "C") = s
Sh.Cells(Source.Row, "D") = ws.Cells(c.Row, "D")
'prossimo foglio.
'riabilita gli eventi
'un range multicelle viene ridotto a una cella sola:forzando l'uscita dalla sub in caso di impostazione multicelle...
If Source.Cells.Count > 1 Then Application.EnableEvents=True: Exit Sub
If Source.Cells.Count > 1 Then Exit Sub
Private Sub cmdAnnoPrecedente_Click()
frmAnnoPrecedente.Show
Private Sub cmdCercaArticolo_Click()
frmRicercaArticoli.Show
Private Sub cmdbuyer2_Click()
Dim wbTo As Workbook, wbFrom As Workbook
Dim wsTo As Worksheet, wsFrom, Sh As Worksheet
Dim Finalrow As Long
Dim FinalColumns As Long
Dim Percorso, tex As String
Set wbFrom = ThisWorkbook
Set wsFrom = wbFrom.ActiveSheet
Percorso = "\CLUSTERFSSharePiano MarketingDb_MasterDb_Proposta_ordini_buyerDb_promo_buyerDb_miglior_promo.xlsm" 'new
Set wbTo = Application.Workbooks.Open(Percorso)
Set wsTo = wbTo.Worksheets("Promo_buyer")
For Each Sh In wbFrom.Worksheets
If Sh.Range("D9") > 1 Then
Finalrow = Sh.Range("D" & Rows.Count).End(xlUp).Row
If wsTo.Range("a1") = "" Then
FinalColumns = 1
FinalColumns = wsTo.Cells(1, Columns.Count).End(xlToLeft).Column + 1
wsTo.Range(wsTo.Cells(1, FinalColumns), wsTo.Cells(Finalrow - 8, FinalColumns)) = Sh.Range("D9:D" & Finalrow).Value
wsTo.Columns(FinalColumns).NumberFormat = "000000"
wsTo.Range(wsTo.Cells(1, FinalColumns + 1), wsTo.Cells(Finalrow - 8, FinalColumns + 1)) = Sh.Range("F9:F" & Finalrow).Value
wsTo.Range(wsTo.Cells(1, FinalColumns + 2), wsTo.Cells(Finalrow - 8, FinalColumns + 2)) = Sh.Range("AC9:AC" & Finalrow).Value
If tex = "" Then
tex = Sh.Name
tex = tex & vbCrLf & Sh.Name
wbTo.Close (1)
If tex = "" Then
MsgBox "Volantino importato con successo"
MsgBox "Impossibile caricare il volantino:" & vbCrLf & tex, vbCritical
Private Sub cmdbuyer_Click()
Dim wsTo As Worksheet, wsFrom As Worksheet
Dim Percorso As String
Dim objExcel As Object
Dim tex, tex2 As String
Set objExcel = New Excel.Application
Set wbTo = objExcel.Workbooks.Open(Percorso)
If wsFrom.Range("D9") > 1 Then
Finalrow = wsFrom.Range("D" & Rows.Count).End(xlUp).Row
FinalColumns = 1
wsTo.Range(wsTo.Cells(1, FinalColumns), wsTo.Cells(Finalrow - 8, FinalColumns)) = wsFrom.Range("D9:D" & Finalrow).Value
wsTo.Range(wsTo.Cells(1, FinalColumns + 1), wsTo.Cells(Finalrow - 8, FinalColumns + 1)) = wsFrom.Range("F9:F" & Finalrow).Value
wsTo.Range(wsTo.Cells(1, FinalColumns + 2), wsTo.Cells(Finalrow - 8, FinalColumns + 2)) = wsFrom.Range("AC9:AC" & Finalrow).Value
MsgBox "Volantino caricato con successo:" & vbCrLf & tex2, vbInformation
wbTo.Close (1)
Private Sub cmdControllo_Click()
Dim controllo As String
Dim expo As String
Dim richiamo As String
Dim disponibilità As String
Dim prezzi As String
Dim periodo As String
Dim tipo As String
periodo = MsgBox("Hai inserito nella testata le date e i richiami?", vbQuestion + vbYesNo, Title:="Attenzione! Controlla la colonna:master?")
tipo = MsgBox("Hai inserito nella testata il tipo e il tema della promozione?", vbQuestion + vbYesNo, Title:="Attenzione! Controlla la colonna:master?")
controllo = MsgBox("Hai verificato se l'articolo in promo é un master?", vbQuestion + vbYesNo, Title:="Attenzione! Controlla la colonna:master?")
expo = MsgBox("Hai verificato se l'articolo in promo é all'interno di un expo?", vbQuestion + vbYesNo, Title:="Attenzione! Inserisci il codice expo nelle note")
richiamo = MsgBox("Hai inserito nelle note se l'articolo in promo fa parte del richiamo?", vbQuestion + vbYesNo, Title:="Attenzione! Controlla la colonna delle note")
disponibilità = MsgBox("Hai verificato la disponibilità dell'articolo?", vbQuestion + vbYesNo, Title:="Attenzione! Controlla la la giacenza o la data di arrivo")
prezzi = MsgBox("Hai inserito il prezzo promo dell'articolo?", vbQuestion + vbYesNo, Title:="Attenzione! Controlla la colonna prezzi promo vpg")
Private Sub cmdData_Click()
frmData.Show
Private Sub cmdgrafico_Click()
Dim Unione As Range
Dim c1, c2, c3, c4, c5, c6, c7, c8, c9, c10, c11, c12, c13 As Range
Dim Percorso As String, promo As String
ActiveSheet.Range("$A$8:$AM$2000").AutoFilter Field:=4, Criteria1:="<>"
ActiveSheet.Range("$A$8:$AM$2000").RemoveDuplicates Columns:=5, Header:=xlYes
Finalrow = Cells(Rows.Count, 4).End(xlUp).Row
Set c1 = Range("A1:A" & Finalrow)
Set c2 = Range("B1:B" & Finalrow)
Set c3 = Range("D1:D" & Finalrow)
Set c4 = Range("E1:E" & Finalrow)
Set c5 = Range("F1:F" & Finalrow)
Set c6 = Range("J1:J" & Finalrow)
Set c7 = Range("M1:M" & Finalrow)
Set c8 = Range("P1:P" & Finalrow)
Set c9 = Range("Q1:Q" & Finalrow)
Set c10 = Range("R1:R" & Finalrow)
Set c11 = Range("S1:S" & Finalrow)
Set c12 = Range("AL1:AL" & Finalrow)
Set c13 = Range("AM1:AM" & Finalrow)
Set Unione = Union(c1, c2, c3, c4, c5, c6, c7, c8, c9, c10, c11, c12, c13)
Unione.Copy
Workbooks.Add
Selection.PasteSpecial Paste:=xlPasteValuesAndNumberFormats
promo = InputBox("Salva Con Nome") & ".xlsx"
Percorso = "\CLUSTERFSShareKommerzLAVORI COMMERCIALECarlo_PirchioSaponi_Profumi"
ActiveWorkbook.SaveAs Filename:=Percorso & promo, FileFormat:=xlOpenXMLWorkbook
ActiveWorkbook.Close SaveChanges:=True
ActiveWindow.Close
Private Sub cmdmixmargine_Click()
Dim area As Range, area2 As Range
Finalrow = Range("D" & Rows.Count).End(xlUp).Row
Set area = Range("AJ9:AJ" & Finalrow)
Set area2 = Range("AK9:AK" & Finalrow)
[G6] = WorksheetFunction.Sum(area)
[H6] = WorksheetFunction.Sum(area2)
[O6].FormulaR1C1 = "=(RC[-7]-RC[-8])/RC[-7]*100"
Private Sub cmdStampa_Click()
frmSeleziona.Show
Private Sub cmdStampaControllo_Click()
frmStampaControllo.Show
Private Sub cmdStampaOrdini_Click()
frmStampaOrdini.Show
Private Sub cmdTema_Click()
frmTema.Show
Private Sub cmdTipoVolantino_Click()
frmSceltaVolantino.Show
Private Sub cmdFiltraUnivoci_Click()
Range("E9:E2000").AdvancedFilter Action:=xlFilterInPlace, Unique:=True
Private Sub cmdimporta_Click()
Dim Unione As Range
Dim c1, c2, c3, c4 As Range
Set c1 = Range("D9:D" & Finalrow)
Set c2 = Range("F9:F" & Finalrow)
Set c3 = Range("J9:J" & Finalrow)
Set c4 = Range("Q9:Q" & Finalrow)
Set Unione = Union(c1, c2, c3, c4)
Percorso = "\CLUSTERFSSharePiano MarketingDb_MasterDb_Proposta_promo_pdvDb_promo_generaleDb_Vol_generale.xlsm" 'new
Workbooks.Open (Percorso)
Unione.Copy
Worksheets("Db_promo").Range("A2").PasteSpecial Paste:=xlPasteValues
Private Sub cmdCaricavol_Click()
Dim Unione As Range
Dim c1, c2 As Range
Set c2 = Range("Q9:Q" & Finalrow)
Set Unione = Union(c1, c2)
Unione.Copy
Workbooks.Add
promo = InputBox("Salva Con Nome") & ".csv"
Percorso = "\CLUSTERFSSharePiano MarketingInserimento_promo"
ActiveWorkbook.SaveAs Filename:=Percorso & promo, FileFormat:=xlCSV
