Sub Recap()
Dim Riga_Tot As Integer, n As Integer
Dim Foglio As Worksheet, wk1 As Workbook
Dim intervallo As Double, inizio As Double, fine As Double, minuti As Double
Dim myRange As Range
Dim cerca As Long
Dim c As Range
Dim d As Integer
Dim Interno As Range
Dim MyColumn As String, Here As String
Dim dopocolonna As String
Dim dopocolonnadopo As String
Application.Calculate
'inizio = Timer
Set wk1 = ThisWorkbook
Riga_Tot = 2
With Worksheets("Foglio1")
' Range("A1:E400").Clear
For Each Foglio In Worksheets
If Foglio.Name <> "Foglio1" Then
With Foglio
Set myRange = .Range("a12:g12")
For Each c In myRange
If c.Value = "mc caricati" Then
Here = c.Cells.Address
' MsgBox c.Cells.Column
dopocolonna = Mid(Here, InStr(Here, "$") + 1, InStr(2, Here, "$") - 2)
Exit For
If c.Value = "mc smaltiti" Then
dopocolonnadopo = Mid(Here, InStr(Here, "$") + 1, InStr(2, Here, "$") - 2)
Exit For
If c.Value = "DATA" Then
MyColumn = Mid(Here, InStr(Here, "$") + 1, InStr(2, Here, "$") - 2)
' c = Range(MyColumn & Rows.Count).End(xlUp).Row
Exit For
'd = Range(MyColumn & Rows.Count).End(xlUp).Row
'Set Interno = Range("B2:T48")
'Range("B2:T48").Name = "Interno"
' Range("Interno").Select
' n = Range("Interno").Range(MyColumn & 48).End(xlUp).Row
n = Foglio.Cells(48, c.Cells.Column).End(xlUp).Row
For n = 1 To n - 12
Foglio.Range(MyColumn & n + 12).Copy .Range("a" & Riga_Tot)
Foglio.Range(dopocolonna & n + 12).Copy .Range("b" & Riga_Tot)
Foglio.Range(dopocolonnadopo & n + 12).Copy .Range("c" & Riga_Tot)
Foglio.Range(MyColumn & 3).Copy .Range("d" & Riga_Tot)
Foglio.Range(MyColumn & 2).Copy .Range("e" & Riga_Tot)
Riga_Tot = Riga_Tot + 1
d = 12
'Loop attraverso le celle della riga12
'Si esce dal ciclo se la cella (Cells (12, d1)) è vuota
While Not IsEmpty(Cells(12, d))
'Scrivere il contenuto della cella nella finestra di esecuzione.
'Debug.Print Cells(3, i + 1)
With Foglio
Set myRange = .Range("Cells(12, d): Cells(12, d + 7)")
' RR = Range("H" & Rows.Count).End(xlUp).Row
' If RR = 1 Then
' RR = 7
' End If
' GoTo Foglio
Exit For
Exit For
Exit For
For n = 1 To n - 12
'Incrementa la variabile di una unità per testare la cella successiva.
d = d + 8
Wend
Next Foglio
wk1.Save
'Application.OnTime Now + TimeValue("00:01:00"), " Recap"
