Sub provincie()
Dim ur As Long, cella As Range, rng As Range, y As Long, v As Variant
With Sheets("Foglio1")
ur = .Cells(Rows.Count, 11).End(xlUp).Row
Set rng = Range(.Cells(4, 11), .Cells(ur, 11))
y = 1
For Each cella In rng
For Each v In Array("appartamento", "villa")
cella.EntireRow.Copy Destination:=Sheets("Foglio2").Cells(y, 1)
y = y + 1
MsgBox "Fatto!"
Select Case cella
Case "MI"
y = y + 1
Case "SO"
y = y + 1
End Select
Next |
Select Case cella
Case "MI", "SO"
cella.EntireRow.Copy Sheets("Foglio2").Cells(y, 1)
y = y + 1
End Select
Next |
for each v in array ("MI","SO")
y = y + 1
next
Next |
y = 1
y = y + 1
next
Next |
Select Case cella
Case "MI", "SO"
y = y + 1
End Select
Next |
Dim wrkPagina As Worksheet
Dim esiste As Boolean
For Each wrkPagina In Worksheets
If wrkPagina.Name = "MISO" Then
esiste = True
Exit For
If esiste = False Then
Set wrkPagina = ActiveWorkbook.Worksheets.Add()
'istruzioni...
' For Each cella In Rng
' Select Case cella
' Case "MI", "SO"
' cella.EntireRow.Copy wrkPagina.Cells(y, 1)
' y = y + 1
' End Select
' Next
Sub fogli()
For Each v In Array("MISO", "TISO", "CISO")
If wrkPagina.Name = v Then
esiste = True
Exit For
ElseIf esiste = False Then
wrkPagina.Name = v
Next |
Sub fogli()
Dim esiste As Boolean, v As Variant
esiste = True
Exit For
wrkPagina.Name = v
Exit For ' <--- qui è il punto
Sub fogli()
esiste = False
esiste = True
Exit For
wrkPagina.Name = v
Sub fogli()
Sheets(v).Cells(1, 1) = Application.Sum(Range("M:M"))
Sheets(v).Cells(1, 1) = Application.Sum(Sheets(v).Range("M:M")) |
Sub sommafogli()
Dim v As Variant
For Each v In Array("FEB", "GEN")
Sheets(v).Cells(1, 10) = Application.Sum(Sheets(v).Range("J:J"))
