=CERCA.VERT(B4;SCEGLI({1;2;3;4;5};Farmaci!B3:B10;Farmaci!C3:C10;Farmaci!D3:D10;Farmaci!E3:E10;Farmaci!F3:F10;);5;0) |
Dim i As Double
Dim lr As Long
Dim ur As Long
Dim rng As Range
Dim cel As Range
If Not Intersect(Target, Range("a4")) Is Nothing Then
lr = Worksheets("Farmaci").Cells(Rows.Count, 1).End(xlUp).Row
Set rng = Worksheets("Farmaci").Range("b2:b" & lr)
Range("a10:f1000").ClearContents
For Each cel In rng
ur = Worksheets("Ricerca").Cells(Rows.Count, 1).End(xlUp).Row
If cel.Value = Range("a4").Value Then
Cells(ur + 1, 1) = cel.Offset(0, -1).Value
Cells(ur + 1, 2) = cel.Value
Cells(ur + 1, 3) = cel.Offset(0, 1).Value
Cells(ur + 1, 4) = cel.Offset(0, 2).Value
Cells(ur + 1, 5) = cel.Offset(0, 3).Value
Cells(ur + 1, 6) = cel.Offset(0, 4).Value
ur = ur + 1
Next cel
| scossa's web site |
| Se tu hai una mela, ed io ho una mela, e ce le scambiamo, allora tu ed io abbiamo sempre una mela per uno. Ma se tu hai un'idea, ed io ho un'idea, e ce le scambiamo, allora abbiamo entrambi due idee. (George Bernard Shaw) |
Dim ur As Long
Dim rng As Range
Dim cella As Range
If Target.Address(0, 0) = "A4" Then
With Worksheets("Farmaci")
Set rng = Intersect(.UsedRange, .Columns(2))
With Me
.Range("A10:F" & .Cells.SpecialCells(xlCellTypeLastCell).Row + 1).ClearContents
ur = 10
For Each cella In rng
If cella.Value = Target.Value Then
.Cells(ur, 1).Resize(1, 6).Value = cella.Offset(0, -1).Resize(1, 6).Value
ur = ur + 1
Next cella
Set rng = Nothing
