Questi sono nei fogli
Private Sub CheckBox1_Click()
If CheckBox1.Value = True Then
Range("A4").Value = "X"
If CheckBox1.Value = False Then
Range("A4").Value = ""
If Range("A4") = "" Then Exit Sub
Dim dh, lh As Range
Dim col As Integer
Dim rig As Long
For col = 3 To 23
For rig = 5 To 37
If Mid(Cells(rig, col), 1, 1) = "N" Then
Set dh = Cells(rig, col)
With dh.Characters(Start:=1, Length:=1).Font
.FontStyle = "Grassetto"
.Size = 10
With dh.Characters(Start:=3, Length:=12).Font
.FontStyle = "Normale"
.Size = 8
If Mid(Cells(rig, col), 3, 1) <> "" Then
Set lh = Cells(rig, col)
With lh.Characters(Start:=3, Length:=12).Font
.Size = 8
Festivita
CS104
polipo
anguilla
murena
Questi sono nei moduli
Sub murena()
Dim T, G, C, D, B, J, TA, CA As Variant 'Mattina
Dim S, Q, R, F, FA, RA, FB, RB As Variant 'Notte
Dim Z, K, W, A, WA, AA, WB, AB As Variant 'Pomerigio
For col = 3 To 9
T = 0 ' Inizio Mattina
For Each C In Range(Cells(5, ((col - 2) * 3) + 1), Cells(12, ((col - 2) * 3) + 1))
If Mid(C.Text, 1, 1) = "M" Then T = T + 1
G = 0
For Each D In Range(Cells(18, ((col - 2) * 3) + 1), Cells(20, ((col - 2) * 3) + 1))
If Mid(D.Text, 1, 1) = "M" Then G = G + 1
TA = 0
For Each CA In Range(Cells(24, ((col - 2) * 3) + 1), Cells(37, ((col - 2) * 3) + 1))
If Mid(CA.Text, 1, 1) = "M" Then TA = TA + 1
TB = 0
For Each CB In Range(Cells(22, ((col - 2) * 3) + 1), Cells(22, ((col - 2) * 3) + 1))
If Mid(CB.Text, 1, 1) = "M" Then TB = TB + 1
Cells(46, ((col - 2) * 3) + 1) = G + T + TA + TB 'Fine Mattina
CL = 0 ' Inizio Pomeriggio
For Each CB In Range(Cells(5, ((col - 2) * 3) + 1), Cells(12, ((col - 2) * 3) + 1))
If Mid(CB.Text, 1, 1) = "P" Then CL = CL + 1
CC = 0
For Each CD In Range(Cells(18, ((col - 2) * 3) + 1), Cells(20, ((col - 2) * 3) + 1))
If Mid(CD.Text, 1, 1) = "P" Then CC = CC + 1
CE = 0
For Each CF In Range(Cells(24, ((col - 2) * 3) + 1), Cells(37, ((col - 2) * 3) + 1))
If Mid(CF.Text, 1, 1) = "P" Then CE = CE + 1
CR = 0
For Each CV In Range(Cells(22, ((col - 2) * 3) + 1), Cells(22, ((col - 2) * 3) + 1))
If Mid(CV.Text, 1, 1) = "P" Then CR = CR + 1
Cells(47, ((col - 2) * 3) + 1) = CC + CE + CR + CL
' Fine pomeriggio
ZA = 0 ' inizio notte
For Each ZB In Range(Cells(5, ((col - 2) * 3) + 1), Cells(12, ((col - 2) * 3) + 1))
If Mid(ZB.Text, 1, 1) = "N" Then ZA = ZA + 1
ZW = 0
For Each ZD In Range(Cells(18, ((col - 2) * 3) + 1), Cells(20, ((col - 2) * 3) + 1))
If Mid(ZD.Text, 1, 1) = "N" Then ZW = ZW + 1
ZS = 0
For Each ZD In Range(Cells(24, ((col - 2) * 3) + 1), Cells(37, ((col - 2) * 3) + 1))
If Mid(ZD.Text, 1, 1) = "N" Then ZS = ZS + 1
ZK = 0
For Each ZH In Range(Cells(22, ((col - 2) * 3) + 1), Cells(22, ((col - 2) * 3) + 1))
If Mid(ZH.Text, 1, 1) = "N" Then ZK = ZK + 1
Cells(45, ((col - 2) * 3) + 1) = ZA + ZK + ZS + ZW
Sub anguilla()
Dim T, G, C, D, B, J, TA, CA 'Mattina
Dim S, Q, R, F, FA, RA, FB, RB 'Notte
Dim Z, K, W, A, WA, AA, WB, AB 'Pomerigio
For col = 3 To 9
For Each C In Range(Cells(5, ((col - 2) * 3) + 2), Cells(12, ((col - 2) * 3) + 2))
G = 0
For Each D In Range(Cells(18, ((col - 2) * 3) + 2), Cells(20, ((col - 2) * 3) + 2))
TA = 0
For Each CA In Range(Cells(24, ((col - 2) * 3) + 2), Cells(37, ((col - 2) * 3) + 2))
TB = 0
For Each CB In Range(Cells(22, ((col - 2) * 3) + 2), Cells(22, ((col - 2) * 3) + 2))
Cells(46, ((col - 2) * 3) + 2) = G + T + TA + TB 'Fine Mattina
For Each CB In Range(Cells(5, ((col - 2) * 3) + 2), Cells(12, ((col - 2) * 3) + 2))
CC = 0
For Each CD In Range(Cells(18, ((col - 2) * 3) + 2), Cells(20, ((col - 2) * 3) + 2))
CE = 0
For Each CF In Range(Cells(24, ((col - 2) * 3) + 2), Cells(37, ((col - 2) * 3) + 2))
CR = 0
For Each CV In Range(Cells(22, ((col - 2) * 3) + 2), Cells(22, ((col - 2) * 3) + 2))
Cells(47, ((col - 2) * 3) + 2) = CC + CE + CR + CL
' Fine pomeriggio
For Each ZB In Range(Cells(5, ((col - 2) * 3) + 2), Cells(12, ((col - 2) * 3) + 2))
ZW = 0
For Each ZD In Range(Cells(18, ((col - 2) * 3) + 2), Cells(20, ((col - 2) * 3) + 2))
ZS = 0
For Each ZD In Range(Cells(24, ((col - 2) * 3) + 2), Cells(37, ((col - 2) * 3) + 2))
ZK = 0
For Each ZH In Range(Cells(22, ((col - 2) * 3) + 2), Cells(22, ((col - 2) * 3) + 2))
Cells(45, ((col - 2) * 3) + 2) = ZA + ZK + ZS + ZW
Sub polipo()
For col = 3 To 9
For Each C In Range(Cells(5, (col - 2) * 3), Cells(12, (col - 2) * 3))
G = 0
For Each D In Range(Cells(18, (col - 2) * 3), Cells(20, (col - 2) * 3))
TA = 0
For Each CA In Range(Cells(24, (col - 2) * 3), Cells(37, (col - 2) * 3))
TB = 0
For Each CB In Range(Cells(22, (col - 2) * 3), Cells(22, (col - 2) * 3))
BT = 0
For Each BV In Range(Cells(5, col), Cells(37, (col - 2) * 3))
If Mid(BV.Text, 1, 2) = "Ma" Then BT = BT + 1
Cells(46, (col - 2) * 3) = G + T + TA + TB - BT 'Fine Mattina
For Each CB In Range(Cells(5, (col - 2) * 3), Cells(12, (col - 2) * 3))
CC = 0
For Each CD In Range(Cells(18, (col - 2) * 3), Cells(20, (col - 2) * 3))
CE = 0
For Each CF In Range(Cells(24, (col - 2) * 3), Cells(37, (col - 2) * 3))
CR = 0
For Each CV In Range(Cells(22, (col - 2) * 3), Cells(22, (col - 2) * 3))
Cells(47, (col - 2) * 3) = CC + CE + CR + CL
' Fine pomeriggio
For Each ZB In Range(Cells(5, (col - 2) * 3), Cells(12, (col - 2) * 3))
ZW = 0
For Each ZD In Range(Cells(18, (col - 2) * 3), Cells(20, (col - 2) * 3))
ZS = 0
For Each ZD In Range(Cells(24, (col - 2) * 3), Cells(37, (col - 2) * 3))
ZK = 0
For Each ZH In Range(Cells(22, (col - 2) * 3), Cells(22, (col - 2) * 3))
Cells(45, (col - 2) * 3) = ZA + ZK + ZS + ZW
Sub Festivita()
' grassetto Macro
Dim dh As Range
Dim col As Integer
Dim rig As Long
'Dim col, rig, As Variant
For col = 3 To 23
For rig = 5 To 37
If Mid(Cells(rig, col), 1, 1) = "F" Then
.ColorIndex = "9"
.Size = 10
Sub CS104()
Dim dh As Range
Dim col As Integer
Dim rig As Long
For col = 3 To 23
For rig = 5 To 37
If Mid(Cells(rig, col), 1, 6) = "CS 104" Then
With dh.Characters(Start:=1, Length:=6).Font
.ColorIndex = "9"
.Size = 10
Sub riformatta()
' riformatta Macro
Range("C5:W47").Select
Selection.ClearContents
Range("C5:W37").Select
Selection.Font.Bold = False
With Selection.Font
.Name = "Arial"
.Size = 10
.Strikethrough = False
.Superscript = False
.Subscript = False
.OutlineFont = False
.Shadow = False
.Underline = xlUnderlineStyleNone
.ColorIndex = xlAutomatic
.TintAndShade = 0
.ThemeFont = xlThemeFontNone
Range("A3").Select
