Call AmboFrequente
Sub AmboFrequente()
Dim ambo As String, ramb As Integer
Dim rig As Integer, urig As Long
Dim i As Long
Dim rng As Range, c As Range, xxx As Range
Set rng = Range("D14:H621")
Range("A:B").ClearContents
'For Each c In rng
'c.Value = Int((90 - 1 + 1) * Rnd + 1)
'Next c
urig = Range("H" & Rows.Count).End(xlUp).Row
i = 2
Cells(1, 1) = "AMBI"
Cells(1, 2) = "USCITE"
'Ambi
For rig = 14 To urig
For ramb = 5 To 8
If Cells(rig, 4).Value > Cells(rig, ramb).Value Then
ambo = Cells(rig, 4).Value & "_" & Cells(rig, ramb).Value
ambo = Cells(rig, ramb).Value & "_" & Cells(rig, 4).Value
Set xxx = Range("A:A").Find(ambo, lookat:=xlWhole)
If xxx Is Nothing Then
Cells(i, 1) = ambo
Cells(i, 2) = 1
i = i + 1
xxx.Offset(, 1).Value = xxx.Offset(, 1).Value + 1
Next ramb
For ramb = 6 To 8
If Cells(rig, 5).Value > Cells(rig, ramb).Value Then
ambo = Cells(rig, 5).Value & "_" & Cells(rig, ramb).Value
ambo = Cells(rig, ramb).Value & "_" & Cells(rig, 5).Value
Cells(i, 1) = ambo
Cells(i, 2) = 1
i = i + 1
Next ramb
For ramb = 7 To 8
If Cells(rig, 6).Value > Cells(rig, ramb).Value Then
ambo = Cells(rig, 6).Value & "_" & Cells(rig, ramb).Value
ambo = Cells(rig, ramb).Value & "_" & Cells(rig, 6).Value
Cells(i, 1) = ambo
Cells(i, 2) = 1
i = i + 1
Next ramb
If Cells(rig, 7).Value > Cells(rig, 8).Value Then
ambo = Cells(rig, 7).Value & "_" & Cells(rig, 8).Value
ambo = Cells(rig, 8).Value & "_" & Cells(rig, 7).Value
Cells(i, 1) = ambo
Cells(i, 2) = 1
i = i + 1
Next rig
Columns("A:B").Select
Selection.Sort Key1:=Range("B1"), Order1:=xlDescending, Header:=xlGuess, _
OrderCustom:=1, MatchCase:=False, Orientation:=xlTopToBottom, _
DataOption1:=xlSortNormal
Range("A1").Select
ambo = [A2]
